Unicode to HTML Decimal Entity Convertion
oeyvind
文章: 1990
註冊時間: 10/03/2001 1:01 am
來自: 大馬/星洲
#1 文章 oeyvind »
Anyone here figure out how to get Safari to take in Unicode text and convert it to Unicode decimal HTML entity?
MSIE on Windows seem to do it automatically for the text inputted via the IME, but not on Mac... :(
真是笨呀! or 真是笨呀!
Guess have to file a bug report, until then one can use this:
http://www.marsengineering.com/charCodeConverter.html
FireFox
文章: 305
註冊時間: 07/24/2001 1:01 am
來自: TX2TW
Re: Unicode to HTML Decimal Entity Convertion
#2 文章 FireFox »
oeyvind 寫:Anyone here figure out how to get Safari to take in Unicode text and convert it to Unicode decimal HTML entity?
真是笨呀! or 真是笨呀!
Try this free unicode utility UnicodeChecker,
which will provide service to convert to and from HTML entity. So, you highlight your HTML entities in the editable text filed, and then select the service. Voila, you get it converted in line to unicode. Very convenient.
Got the info from Yale's Chinese Mac FAQ page.
--- This message is composed with 100% recycled electrons.
