是使用mac的新手,所以想請教一下.
我的poerbook G4是以前實驗室的,因為剛剛使用mac system,不熟,所以想請教大家一下..
在ㄧ個偶然的情形下,有程式須要在os 9中執行,但是卻沒有OS 9在電
腦中,我曾自己試著重灌但是OS 9抓不到硬碟,也去過apple center,但是其工作人員也無法灌入,他還告訴我說我的電腦沒有裝OS 9的driver,所以光碟開機找不到hard disk,他最後給我的建議是partion重灌所有的東西,但是我不想這樣做.. 因為有太多的東西了..
想請教大家一下,可否有不改變現在的情況下,灌入OS 9
我也曾經copy其它的電腦中的OS 9,但是還是不能用 (這是工作人員說的,我也不知道)??
my powerbook G4 800MHz with 512MB Memory
無法灌OS 9 in powerbook G4
can you give us more details on the model of your pb g4???
the newer models of mac cannot use os 9 as the operating system, but only through the classic environment.
what you can do is to get your hands on the original system restore cd/dvd of your pb g4 and do a software restore on it...
all macs that come with os x has os 9 installed, even if when some of them cannot be started up with os 9.
fuigo
fuigo
