其中在其他下的軟體便是"Deja Vu".
最玄的是我根本沒去下載此項軟體??
還是OSX 10.3.4裡有內建??
如果不想使用該如何移除呢??
那好像是跟Toast 6 Titanium邦兜的玩意zhong 寫:我的PB在系統偏好設定中多了一項其他.
最玄的是我根本沒去下載此項軟體??
還是OSX 10.3.4裡有內建??
如果不想使用該如何移除呢??
Deja Vu 是 Toast 的附帶工具,您應該有裝 Toast 吧,看看吧:zhong 寫:"?"按下去了,可是並沒有告訴我如何移除?
To uninstall Deja Vu, follow these steps:
Open the Deja Vu system preference and select "Disabled" from the popup menu. This will remove the backup scripts from your system.
Drag the Deja Vu preferences pane (DejaVu.prefPane) to the trash. It's located in hard disk/Library/PreferencePanes/ folder.
If Deja Vu is still showing up in System Preferences after performing step #2, then delete the following file which has not yet been updated by the System Preferences: Home/Library/Caches/com.apple.preferencepanes.cache.
你稍微了解一下Deja Vu你也許就不想移它了,它是很好的backup 軟體。 systematic and automatic.zhong 寫:我的PB在系統偏好設定中多了一項其他.
最玄的是我根本沒去下載此項軟體??
還是OSX 10.3.4裡有內建??
如果不想使用該如何移除呢??
